I have an issue...no side lights nor rear tail lights
Hi guys,
Thlught i’d start a seperate topic for this issue incase it helps others in the future.
Ok, so i was in the process of changing the side light bulbs on my 2008 Aygo today from standard to led, did the drivers side first, switched my lights on to test and yay it lit up, stupidly i admit, i moved to the passenger side light bulb, too lazy to switch my lights off first, id like to blame the freezing weather at the moment, i whipped out the old standard bulb, inserted the new led bulb...and boom, the drivers side light bulb went dead, and so did my rear lights, all the other lights work fine.
Could it be a fuse? And if so which one? I managed to find the fuse box behind the steering cowling, however there are fuses to the right and left of it...i cant see any fuse locations in my haynes manual...i hope its nothing serious.
Please help.
Hi guys,
Please help.
Well some bulbs when you touch the glassy area they blow out, may be I think it could be the reason
Sent from my iPhone using Tapatalk
Hi All
All sorted...removed speedo cluster...via 2 screws...behind the steering wheel...easily accessed by turning the steering wheel...after which pull cluster up and off...right hand side fuses...4th from the top...brown 7.5amp...side and rear lights working again...yay !
