avensis key fob
toylexus
Hi all/ got a petrol avensis 2004 and noticed recently the car is getting harder to open, have to press button on fob 7 times or more, thought Battery but it locks fine first time and from a distance locks first time. Anyone any ideas, thanks in advance
Had same problem with my fob, closed easily but had trouble opening.
I changed the Battery and problem solved!
Seconded; If open/closing works all the time but closing/opening doesn't, it's usually either local interference or the fob Battery. If it only does this in a certain location it's likely interference, but if it's everywhere then it's the fob Battery.
It's a bit counter-intuitive as you'd expect a low Battery to affect opening AND closing, but for some reason it always seems to affect one more than the other!|
Don't want to create a new topic.
Guys, on my front left window I have a toyota sticker with some wires (?) in it. Do I actually need that sticker? Is it for remote lock/unlock? Coz I hate it there and would like to remove it.
The sticker won't play any part in how the remote locking works and can be removed if you wish.
