I have 2 issues about which I am looking for advice - if anyone here can help I would be most grateful:
1. Both of our electronic key fobs have lost both rubber buttons so we have to jam our finger ends into them to unlock/lock the doors. How easy is it to get these fixed/replaced? Any ideas as to likely cost?
2. The decorative strip running about knee height along the bodywork on the nearside is coming away. Does anyone have any tips on what type of adhesive is best to stick it back down reliably?
Many thanks in anticipation.
The rubber buttons are readily available via the internet at < £2.  IIRC some offerings are 2 button, some 3 button (which I think you can cut down to 2 button if needed).  Replaced both mine at different times.  You need a very small cross-head screwdriver to get inside.
Can't help re the rubbing strip.
Thanks to both notoyboy and frostyballs for swift replies.
