Mirror indicator removal tips
blocker
Hi all.
My wife's wing mirror got hit, breaking the indicator glass and cover. I bought a full unit off eBay but im not sure if the indicator unit comes out. I know you can buy that part alone from Toyota so im sure it does, but it isnt obvious how to do it. Any ideas?
Cheers all.
Managed to dislodge mine a few times on the garage door frame.
Snatched from "Yarisworld":
"If I'm correct they will come out by removing the mirror glass first (push all the way up, then unhook gently with hands from the bottom--search in the forum) and the cover's clips should be visible/accessible from there (the inside of the shell)."
...and...
"I managed to get it all sorted. I popped the mirror off and that allowed me access to the cover tabs on the inside and so it came off without a hitch."
