Hybrid battery charge
Jonmartin
How long does the Hybrid Battery hold its charge ? Despite it being nearly fully charged when I park, when I return some hours later it shows nearly fully discharged.
That’s not right, mine doesn’t seem to discharge at all.
Should hold it’s charge ,from the manual
“However, if the vehicle is left parked for a long time the hybrid Battery (traction battery) will slowly discharge. For this reason, be sure to drive the vehicle at least once every few months for at least 30 minutes or 16 km (10 miles). “
So a few hours should have no real effect. A hybrid Heath Check my be the way to go,
Yeah, the traction Battery isn't even connected when the car is off so if it's discharging there may be a duff cell. It's rare, but it happens. I'd recommend the hybrid health check too!
Hopefully the Battery is still under warranty!
Going by his profile it's a 2016 so should still be under warranty (assuming serviced to schedule). I would consult my dealer.
I think everything is fine. Thanks for everyones help and comments.
Did you not have an issue then Jon? I’m intrigued!
I thought I did, but no. I realised that I’d parked up for the night with a fairly well flat drive Battery
Ahhh ok, glad it was nothing to worry about! Cheers for the info. All the best.
Glad it was nothing! Thanks for posting back to let us know!!
