Hi all,
Had a cold starting problem for several months on my Corolla Verso TR 2.2 D-4-D engine, getting worse, lots of cranking, eventually start with lots of white/grey smoke, then runs fine absolutely rest of the day. Two local garages didn't seem to want to spend time finding fault, but second said problem is probably a failing SCV. They only get the part from Toyota (£310) and seeing online this part is easy to access on fuel pump (HU 294000–0314) and just two allen key bolts, I thought
