Window Lock on just rear windows possible?
I have a 2008 Corolla Verso. In my old Mondeo I could lock just the rear windows, leaving the front passenger one free to operate.
However, I notice in the Corolla that the window lock affects the front passenger also, leaving the drivers window the only that can be operated. Can this be changed so the lock button only affects the rear windows?
Not as far as I'm aware.
As Frosty says, not something thats available as an option.
However, looking at the wiring diagram for the standard Corolla, it should be possible, but you need a full diagram for your model and someone with the ability to work out the wiring modifications to make the Lock button controls all three windows
What would probably be simpler is to fit a separate switch  that isolates the control power to the two rear windows .
