No power no faults....1nd-tv
Fabiol
Auris starts perfect,no smoke black or white,revs go up no problem when not in gear,when driving no power,no fault codes, any ideas??
Moved to the Auris club.
First port of call would be the fuel filter, when was it last changed?
Done that,no change,the fuel pressure in the rail is in correct values...
Ok, when driving does the Actual fuel pressure closely match/follow the Target pressure of is there a significant difference/delay in the pressure
Fuel pressure was ok,all data I could check was done,all passed...
Found the problem,fuel injector...the only way i was able to detect this was by trying a working set...not my usual way of doing things but I had no choice....in the weekend I will post the full story...I found help  in the web lots of times and maibe my little drama can help others in the future 😀
Thanks for taking the time to help and posting valid ideas, let you guys know the full story during the weekend
Glad you found the issue, when replacing any injectors make sure the "Compensation code" of the new injector is written into your engine control unit.
