Bad transmission or elect issue?
Mark James
Hello
My first time here
I have  a coworker, 3 week ago she purchased a 1998 Toyota Rav 4     automatic  4 cylinder she has ECM so  it can be  4 wheel drive?
 IN her 2nd week it began to slip, then it could not climb a hill.  Then a few days later it did.  I checked it out.  I had to add 3 quarts of tranny fluid for the Toyota.  It still slipped.  I drove it around the parking lot.
Tests: if it started to slip I would shift to 2nd that helped a bit.
If I slowed down it would grab, slowly accelerator would start to slip.
If I stopped than started in 2nd okay drive around the lot a few times let off gas for a turn  accelerate again it would start to slip  let off gas it would go forward.
In our parking lot dead stop I would punch it. It would accelerate  & shift in the 120 yard stretch normally. Slow down turn the corner it would slip then grab.
IN reverse it works perfectly--- normal.
I turned on ECT, it would Performed a bit better but would slip
 ECT ON overdrive off it would Performed a bit better but would slip
Turned off overdrive, seemed to work better, I was too confident and took it to the street.
Half way up the hill it started to slip, speedometer would race to 90 MPH, pulled over trans engaged.  I had to continue up hill.
On a 1 mile stretch of highway I could not get it over 20-30 mph . Slipping. Off the freeway down a hill back on to a surface road going back to work. It would not stay in gear. Shifting did not help. I pulled up a side road to avoid the main street back to work. It would not climb.  I would stop. It would not engage. Finally after a few minutes it grabbed. I proceeded up an incline for 1 mile constantly changing the throttle it would slip and speedometer would act like a tachometer.
A couple times on this road test there was a screeching sound of metal on metal. But only a few times.
Hoping it might be something other than a total loss for her.   She spent 3K, not worth the cost to get a tranny. Since she still owes on it. Purchased from a private party.
Any thoughts?  Thank you
