handbrake warning
tcpnul
After starting the car while front jacked up,warnimg message came on and stays on.
I believe this is common.Any solution please
Check your brake fluid level first
What is the message displayed? Can you take a picture and upload, because it will be easier. Take another photo to show any other warning lights whilst the engine is idling.
I would not say it is common. I only had the message come on due a mechanic not properly securing a connector to a gearbox sensor, after the clutch was replaced.
Another poster had a problem which turned out to be caliper pins -
Before going down the route of replacing the actuator costs a lot of money, check the brake calipers to make sure nothing has seized.
The actuator does not like moisture, so wading fords or jet washing is certain areas is a big no no.
