Avensis 2.2 d4d
Nightblind
Hi. Trying to find out if my car has a dpf filter? 56 reg 2.2 d4d  T25. Called 5 different Toyota main dealers 3 said no, 2 said yes!
Also any advise on a good Obd scanner for avensis that will give real time info on egr,  o2 sensors, trc, vsc. Must be u.k not u.s and would prefer iOS compatible.
do you know what power output (150 or 180)?
Manual or auto transmission?
If you open the bonnet does the engine cover have D-CAT on it?
It is a t spirit. Don’t know where I find out if t150 or t180?  Manual. Just says d4d on cover. Have looked all over car and can’t find any stickers.
If it is a UK registered T-spirt then it is a 150bhp ( T180 trim had the 180 bhp engine ) then it will not have a Diesel particulate filter.
