MOT - new smoke test limits from May 2018
FROSTYBALLS
The amended limits to be applied from 20 May 2018 are:
Vehicle first used before July 2008 None turbo 2.5m or plate value if lower
  Turbo 3.0m or plate value if lower
Vehicle first used on or after 1 July 2008 All diesels 1.5m or plate value if lower
Vehicle first used on or after 1 January 2014 All diesels 0.7m or plate value if lower
Note: Plate value is the emission limit specified by the vehicle manufacturer and can be found on the vehicle manufacturer’s plate. If there’s no emission value on the manufacturer’s plate or it can’t be located, then the alternative default values must be used.
See https://www.gov.uk/government/publications/mot-special-notice-07-17-replacement-documents-and-smoke-test-limits/mot-special-notice-07-17-replacement-documents-smoke-test-limits-and-annual-assessments
  • 2 months later...
Thanks for the heads up on this. Regarding the diesel, it is well worth paying for a couple of consecutive fills of V-Power or BP Ultimate into a diesel every year especially if the car has been run on pure supermarket diesel that has no additives that are required to keep diesel healthy as well as the environment and our health. Visible smoke was completely eliminated and pollutants did drop on MOT. I know all D4-D loves V-Power.
Not sure it works for petrol though, I remember premium stuff made the Toyta petrol 1.5 smoke a bit for ages so never went back.
