2007 D4D - Water sound in Dashboard?!!?!!
astrobhoy
I've just bought a 2007 2.0 D4D and I noticed many times that when I start the engine there's like a short rush of water sound coming from the front dashboard!!  It's weird - almost like I've switched on a pump!  The front screenwwash pump doesn't work either - likely just a new pump needed.  Any ideas what this is?
I noticed the same thing after a coolant change. Maybe check it's level.
I have a 2007 2.0 d4d as well, mine started doing this last year and it was caused by head gasket failure. Other symptoms are coolant loss via filler cap and overflow pipe, coolant smelling of exhaust and turning black. The coolant gets sprayed over the front of the engine cover. Hope it's not the same on yours. Check the water pump as well, mine had been weeping and running down the engine by the front pulley.
Had this on my 56plate d4d. Run the heater on full for a bit and it should prime the system. turned out to be a failing water pump on mine.
