Confused
breezer
Can Amps not be run in tandem ?
I am no expert on Car Audio.... but I used to work gigs doing sound n stuff and you can run amps together...
I found this... dunno if it is informative.. *shrugs
Outside Link to some forum :P
big convo :huh:
Lol! its just i have one amp hooked up atm to power a sub.
And i want a lower wattage one hooked up also to power some Speakers.
The power for the amp is easy, you just need to split the feed from the Battery using a power distribution block.
Normally to have 2 amps doing different things you're best using a head unit that has multiple RCA preout's. I'm not really sure how you can split a single signal from an RCA converter...
just what i said on the other thread all ya do to split the rcas id get the correct splitter which costs a few quid
