07 Avensis Petrol Tourer - whining noise at speed
gliese581
After my last post saying my great Tourer has never gone wrong, its now making a funny noise! Its got a loud persistent whine above 40 mph. When you knock it in to neutral the whine continues, which makes me think maybe a wheel bearing, or something that is moving outside of the engine. Local garage says nothing wrong with the wheel bearings that they can see. Does anybody have any thoughts? Are circa 07 Avensis prone to a problem like this, and if so, what is it. I'm thinking maybe gear box on the way out? Any thoughts appreciated. Thanks.
Sounds like a wheel bearing
Sent from my iPad using Tapatalk
It could be the wheel bearing, but to be sure, increased the tyre pressures to about 36 psi. I have had tyres that sound the same as a failing wheel bearing, and when I pumped them high the sound stopped. One of the tyres had internal structural failure, due to age and wear and tear.
If it is a wheel bearing, the tricky bit is to find out which one. I had changed wheel bearings myself and the hard bit is getting the inner race from the inner hub - I have my own press.
