Toyota Carina 1987 Parts
Hi All
Got a 1987 Toyota Carina ii GL Saloon Auto (AT151)
The fuel gauge sender unit has died (the copper wire broke)
Does anyone know where I could source a new fuel sender unit from, or does anyone have one lying around.
I did manage to find one in the usa but its going to cost an arm and a leg to get it.
Failing that does somewhere repair the fuel sender units at all?
Welcome, m8 :smile:
Wedgehog has a 'spares car'!
2sav
Thanls 2sav sadly he doesnt want to help me out "parts car for his use only"
Need a sender unit 4inch diameter with 7 screw holes and about 5inch distance to end of the float
Do you have the part no? Likely an alt fitting, possibly Corolla/Celica/Camry :wink:
Problem with ALL old European Toyyos >>> straight off to four corners of the earth. They are Car Breakers Gold!
BOL m8
2sav
According the epc im looking at a 83320-80016, The fuel sender in the car has no numbers what so ever.
But i got 83320-29797, ""-29796, ""-29798, ""-29898 that may fit as a carina, but non of these fitted other cars
This rate i will stick one out of my morris minor into it with an adaptor plate to the tank haha
As the 'working bit' is a rheostat that drives a Toyota gauge... I might guess that other Toyota fuel senders are in a zone of calibration/compatibility.
Perhaps finding 'any' Toyota fuel sender (ignoring float arm) which is the same configuration into the tank hole/dia/screwholes.
Its a thought :wacko:
2sav
Thanks 2sav could be an idea.
By a unit thats from a similar era and take it apart to put that rheostat into my original one.
Thanks for your advice :)
