Mis-fuelling
David Thomas Thompson
what is the consequence of mis-fueling a 63 plate avensis tourer  diesel. ran short distance, drained ,flushed and refilled, ranok for 40 iles in 8 mile journies now after stopping engine will not restart as if fuel system is airlocked. any advise?
Title edited, and moved to the Avensis club.
How short a distance did you run it for? The diesel fuel is also usually used as a lubricant for the fuel pump, petrol strips away that effect so the fuel pump may be damaged.
https://www.theaa.com/breakdown-cover/advice/wrong-fuel-advice
10 miles. vehicle is now running fine Thanks
after drawing off fuel and refilling I put some diesel lubricant / exhaust cleaner to tank. since then on the first fill of 48 litres of Ultimate I also added some injector cleaner.
Many thanks David
