Service items
saab9002
Evening all,
Just bought air filter,oil filter,sump plug and a set of spark plugs for my iq3, the latter is a slight concern,
the plugs are Denso  ixeh22tt which were the ones recommended by GSF and I got 60% off everything.
Are these the correct plugs?
If it's any use to anyone on here,
The code is gsf60 but only good until midnight.
regards Chris
They look correct from images I can find of them. I bought my plugs from Toyota and they were Denso ones in Toyota boxes but not sure if they had a part number on the side.
Changing the plugs isn't too bad if you are going to attempt them yourself. You don't need to drain any coolant and the inlet manifold has to come off but that has reusable rubber seals so long as you are careful, it will all go back together quite easily.
You will need a filter tool for the oil filter housing as you can't get near it with a strap wrench and they are normally pretty tight.
Craig.
For the 1.33 Toyota list
SC20HR11 for cars built up to Nov 2013
SC16HR11 for cars built from Nov 2013
