Loose back on front seat - Falls down in lie-flat position
kurbitur
I have a Yaris (2006) and the movable back on the front passanger seat won´t hold it´s position.
Well... usually on a green traffic light when I accelerate the passenger falls backwards and is lying down like he´s in the dentist chair....
Rarely the seat is ok and it´s only fasten in the  uppermost position (90°) which is very uncomfortable
Sometime´s it´s ok but one speedbump and it´falls down
Any idea what might be causing this problem?
Kurbitor Hi,
 Use a flat screwdriver (or similar) from the top and prise recline lever off. There's usually a bolt through the recline mechanism, re-tighten it with seat upright. If it's already tight it's a trip to the scrappy's as the mechanism has probably stripped. Good luck.
