Avensis 2008 Radio/MP3/GPS unit problem
rocker69
Hi Folks.I have a 2008 Toyota Avensis TR D4D estate and i recently got a ''new'' Radio/MP3 CD player/GPS unit with model number B9010  for it from at exact same 2008 Avensis  TR. After all (connections and fitting to the panel) the radio won't turn on and it says " a program cannot be read. please consult to a dealer''. Does anyone have a same problem? does anyone find a solution to this? i know for a fact that it is %100 working unit .thanks.
Hi Roman, welcome to TOC :smile:
does it have a disc in the map slot?
No, all slots a empty, i got a bundle of 4 discs with maps.
It probably needs a disc in the map drive to initialise.
Yes!yes!yes! it was a very simple think - you need to insert any of 4 map disc's in to a map drive to initialize a system, so, info to anyone who will have a similar problem, if you change a car Battery or for some reason you have to disconnect a car Battery, don't forget to insert a disc after you reconnecting a Battery again. Heidfirst - thank you very much for your time and your experience and for your hint!    Kind regards Rocker69.
Moved to the Avensis club.
Yes it is a known subject with the Nav unit and discs. My friend had the same problem with his 2008 TR, when the Battery was disconnected -
On thing I will add, is that once the unit has finished initializing (leave it for a few days), you can remove for security purposes. I am aware that some owners have had their discs or SD cards stolen, when the car is left at garages or other places!
  • 3 years later...
Hi
I also have a toyota avensis 2008 which has the same error sign, 'a program cannot be read' and the radio will not switch on. However the radio unit has the disc inserted in the bottom player yet still won't work. Can anyone help?
  • 2 years later...
On 2/9/2018 at 12:10 AM, rocker69 said:
Yes!yes!yes! it was a very simple think - you need to insert any of 4 map disc's in to a map drive to initialize a system, so, info to anyone who will have a similar problem, if you change a car battery or for some reason you have to disconnect a car battery, don't forget to insert a disc after you reconnecting a battery again. Heidfirst - thank you very much for your time and your experience and for your hint!    Kind regards Rocker69.
@rocker69 i'm looking all Over for those discs... My car is 2hand and didn't have them! Can you sell me a copy of them...! I know it's a strange thing to ask, but it's the second time i have that problem because of a problem on the batery..! I'm from Portugal but maybe you Can send it at my cost or maybe send it by Internet, dropbox or similar... Thank you in advance!
  • 2 months later...
  • 10 months later...
Where can you normally find these discs or if they can’t be found where can I buy one
thanks
Hi & welcome to TOC.
You normally find it in the map DVD drive of the head unit ...
If you don't have one try eBay.
I take it that you also have the "a programme can't be read" message? If so, it's the system looking for the loading.kwi file to initialise.
