Oxigen sensor location
Lauri Kasper
Hello everybody
I am a little bit  confused  I have a 2006 Toyota avensis  2.0 D4D and the problem is that carage where i went  with my bad MPG and hot engine ideling vibration problem told me that i have to replace the oxigen sensor. So now i hope that somebody can pinpoint me where it is located because i cant realy find it where it should be or is this car realy have this sensor?
Every info i get from all of you  will be very helpful.
To confirm that the oxygen sensor is at fault there usually warning indicator - the EML (engine management light) on the instrument display will be on all the time, and then using diagnostics via the OBD port, to get a code which will confirm the fault by giving a code reading.
Location of sensor may be as the following - http://www.japan-parts.eu/toyota/eu/2006/avensis/adt250l-alfnyw/3_273550_131_352w/electrical/8401_switch-relay-computer#89467B
