New Member - Service Parts
BAZ101
Hi All,
Just recently replaced my Corolla, after 7 years of trouble-free motoring, with a 2010 Auris SR 1.6 Valvematic in white with tinted windows.
The car has just passed 60k and is due a full service. However, I am having difficulty in sourcing the correct spark plugs (Iridium?)and oil filter. There seems to be a few choices on the online parts checkers for the 1.6 petrol.
Can knowledgeable members please confirm if these plugs and filter from ECP are suitable:
NGK Spark Plug:
https://www.eurocarparts.com/ecp/c/Toyota_Auris_1.6_2010/p/car-parts/regular-service/car-service-parts/spark-plugs/?408992420&1&42631b4612c45415473d1ce4341419ecb330aade&000301
MANN-FILTER Oil Filter:
https://www.eurocarparts.com/ecp/c/Toyota_Auris_1.6_2010/p/car-parts/regular-service/car-service-parts/oil-filter/?501820159&1&1ad374105a257e5430bd9336b882bf590e398c7d&000231
If the above are not suitable, please can you recommend the correct ones.
Thanks for your help.
Kind Regards,
Baz
you can use  either NGK ILKAR7B11 or Denso SC20HR11. Your engine has Denso spark plugs on it.
You need mann W 68/3 oil filter or similar.
Thanks Dzerdin,
I thought the oil filter was just a paper one? The mann W 68/3 is the screw on type.
You could check /ask here or at your local T dealer. some service parts prices are reasonable.
http://stores.ebay.co.uk/ToyotaOfficialStore/_i.html?LH_TitleDesc=1&rt=nc&_nkw=Auris 2010&_sid=1173390832&_trksid=p4634.c0.m14.l1581&_pgn=5
Am also a Corolla owner considering an Auris, be interested in your thoughts about the differences for better or worse, now you have driven it a while ?
If you are looking for genuine parts you will need:
04152-YZZA6 - Oil filter element
90430-12031 - Sump plug washer
17801-0D060 - Air filter
90919-01253 - Denso SC20HR11 Spark plug x 4
87139-YZZ16 - Pollen filter
08880-83265 - 5lt 0w20 TGMO oil ( needs 4.2lt )
