Recommend best diagnostic software PRO OBDII for 1.4D?
Do you all recommend this for my Corolla 1.4d 90bhp?
http://www.ebay.co.uk/itm/Toyota-Corolla-OBD2-Professional-Car-Diagnostic-Code-Reader-Scanner-Tool-KW808/151806212510?hash=item23585af99e:g:iTgAAOSwcwhVRLcR
What happened is yesterday drove in night and I hit a massive pothole lucky did not damage my wheel and etc. but the light comes on is ABS and AIRBAG light must have lose the wiring. This morning the lights still on, my RAC diagnostic did not detach error numbers, my friend said this is low base what I need is a PRO diagnostic for search deeper error codes.
Yes?
Yes but not so sure if it tells you what the code description is, just the code itself
You need to buy one that clearly state is reads ABS and SRS codes, the one you link does not, as do most cheap ones.
Though there are  lots advertised  stating ABS/SRS but cannot say which ones are best, never used the high end ones.
Seems to remember folk mentioning the Autel and Foxwell are ok, looking around this looks like it MAY be suitable, but am no expert.
https://www.ebay.co.uk/itm/Autel-Diaglink-OBD2-Auto-Diagnostic-Scanner-DTC-Code-Reader-ABS-SRS-EPB-for-DIY/172833626154?epid=8010935922&hash=item283dafd82a:g:L2AAAOSw94taBCrV
Sorry for delay thanks for the link and I have bought it, this do found the faults is ABS sensor on passenger front and the airbag under the seat connector coming loose. All is fixed by me very happy thanks.
