VSC/TRC not lighting when key first turned on
dogman
VSC/TRC lights do not come on when key is first turned on, anyone able to suggest what to do? The 4wd appears work.
I would expect all lights to come on as a lamp check when ignition is first turned on - so the assumption is that the lamps are defective.
