Aerial / Antenna Base for 2002 RAV 4
eddiey1
Hi the antenna base on my 2002 RAV has been broken - I am trying to find a replacement but am not having any luck. Can anyone recommend good quality replacements.
Also, how difficult is it to fit? Is it a standard DIN connector? thanks
The part number for a new base is 86300-42100, you will need to drop the rear headlining to access it the base is pre wired and powered ( it contains a signal amplifier) and joins the cars wiring harness up in the void between the roof and headling.
As it is unique to Europen Rav4's it is unlikely that the aftermarket would bother with offering a part with such a low demand, so you are most likely going to have to try eBay, scrapyards or a dealer ( make sure you are seated when asking for the price of a new one )
Hi thanks for that information, that is really useful. The part number is a god send! I am going to try to find one at a scrap yard! cheers :cool:
As it is unique to Europen Rav4's it is unlikely that the aftermarket would bother with offering a part with such a low demand, so you are most likely going to have to try ebay, scrapyards or a dealer ( make sure you are seated when asking for the price of a new one )
Thanks again to DevonAygo - the part number enabled me to find the part at a scrap yard for £16!
