Toyota Avensis Tr 2.0 d4d 2011
Darren Parker
Hi can anybody help me with this problem or suggest anything to try? The car has 145k on the clock a couple of months ago the dpf packed in after being cleaned 3 times was then told it had collapsed in centre.i then found a smashed up toyota and bought dpf off it it had only done 40k so thought better to buy and origional dpf than a aftermarket one. Garage fitted it gave car car back..striaght away the car was chattery when accelerated and before getting to temperature it would blow out a plume of light grey/blue smoke. and fuel economy is well down.went straight back to garage they investigated further told me one of injectors was faulty..brand new origional injected bought..put in car ..car was still same..after 5 or so trips back to garage the car ran exactly same..same symptoms..this was an independant garage..by this time had enough..took it to toyota garage they checked all injectors..pilot learned etc has all latest software update in car yet i still have fault..toyota told me cant find fault has no fault code found on system?
been reading other forums this car has a 5th injector..does aanybody know where abouts on this car this injector is? and could this be my problem that is making my car chattery occaisonal smoke and poor fuel economy ? Any sort of help or suggestions i would be very grateful Thanks.
Moved to the Avensis club
