Avensis doors squeaking noise
Blagoj
Hello to everyone,
Whenever going over bumps or uneven ground which twists the frame, and at speeds between 40-80 km/hr, my Avensis doors make a squeaking noise.  It is very annoying, taking in consideration that this is a new car, while the previous model I had (Avensis 2008) did not have it.
Any advice on this?  Does anybody else have or had this bad experience, and if yes, how should I resolve it?
Thank you in advance.
You could try spraying a dry silcone lubricant on the door seals and anywhere you think the noise might be coming from.
Yes, I've had this noise on our Auris and Avensis, silicone spray lube on the rubber door seals stopped it on both.
