Toyota Landcruiser J92
curlyearly
Hello All
I would like to fit 33x12.5x15 tyres to either 8 or 10" wide rims. My suspension is standard and there seems absolutely bags of room around the arches.
Can I fit these tyres / rims without need for modification?
Awaiting loads of replies, hopefully.
Earl
dont see a problem, wheel offsets and clearence are your major concerns........when suspension is compressed!
Hi Earl If your landcruiser is a 90 series prado/colarado there is only about 10mm clearance on the inside when the steering is turned.Im not sure if its the brakes or steering.
Ive seen this on the aussie forums a few times.
If you own 60,70,80 or 100 series landcruisers the tyres will only fit without rub if you do a 2 in suspension lift. Even then 12.5 may rub on the arches when turning under compresson.
I use BFG 33x10.5x15 A/T on my 73 series and they are perfect.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
