T270 remote locking flashers
mac_101
I recently purchased a 2017 T270 with 10K on the clock. Everything is fine apart from the flashers do not operate when remote locking the car. Does anyone know if there is a switch to disable these?  I dont want to take back to Mr T and look silly if it is something as simple as that. Thanks
I can't remember exact screen sequence atm but if you go into the Touch 2 there is a section where you can change some limited behaviours.
Also, the dealer (or you if you have the equipment) can probably modify more using their Techstream software.
Hi Alastair,
Switch on the ignition and on the Touch 2 go into SETUP - Page 2/2 - Vehicle (wait for it to be highlighted) - Vehicle Customisation - Door Lock Settings - Lock / Feedback Lights - Tick.
Hope this helps.
Thanks guys - that is now all sorted. I had been looking in the main Avensis owners manual, I did not think to look in the Navigation manual. Thanks again!
