Everyone seems to be a very knowledgeable.  I have a vibration  in drive when stopped, but not at acceleration. Also trouble start.  It takes two oir three tries before the car will start.  Items replaced in the last month:   motor mount, injectors, fuel pump, fuel regulator, fuel filter, plugs and wires.   Are the purge valves solenoid evap, known to cause vibration and starting issues?  Also car seems to run fine when rpm 1400 and above, and when in neutral.   Car is 1999 corolla, with 60k.
Moved to the Corolla club.
