Hi All,
I did a coolant flush Sept 2014, I may have topped up after a year or so with about 300ml (concentrated) that was left over from the flush job.
Its now few mil above the Min mark on the, I am guessing this is normal and its evaporated over time as there is no visible leaks.
I ordered 1ltr concentrated pink but dealer sent me 5ltr pre-mixed, if I use a bit...guessing it will take a litre from Min to Max? How long will the left over stay good in the container?
Thanks.
When did you last check the level  2015 ?  if so you have no idea if its a gradual or sudden lost.
You need to refill to Max and then monitor a couple of times a week to see how quickly is going down.
Mine dropped slowly for years, but when I replaced the thermostat it was clear it had been slowly weeping from the seal, but evaporating before it became visible to a casual look from above.
You could have a slow leak from your water pump or any hose  or the rad cor or CHG .
If its still goes down fast and you cannot spot the leak , you need a pressure test.
Thanks Oldcodger foor your reply.
Last time I checked was during the oil change, about 6 months ago, it was just below the mid level.
I'll have a noise around properly when the weather gets a bit better. In the meantime I will fill it up and monitor closely.
Other than this and the oil leak behind the engine block, the car is running fine I think, mileage isnt great but that maybe due to heating being on.
Whats CHG?
16 minutes ago, roks said:
Whats CHG?
Cylinder Head Gasket
Thanks frosty :blush:
