Location of fuse box in 64 plate aygo
Please please please can someone tell me preferably show pictures of where the internal fuse box is on a 64 plate aygo. We have taken the dash apart, glove box out searched everywhere. Manual is  worse than useless. Need to find it to check fuse for 12v cigarette lighter.
Toyotas are only supplied with an abbreviated owners manual - the full owners manual can be downloaded from https://www.toyota.co.uk/tme#/my-toyota/eManual which will show where the fuse boxes are and have pictures
The dashboard fusebox is located behind a cover on the underside of the dashboard on the driver's side, below the air vent and mirror controls. The power outlet fuse should be no.9.
I have looked there and have taken a photo, what am I missing? There is nothing behind the blanking plate either?
I found this on the inside of the drivers door by the pedals but I can't see any fuses?!
This is under the dashboard! Is this a model with only a fuse box in the engine compartment and if so any ideas which fuse it is?
  • 5 months later...
Did you find the fuse box? My car looks the same as your photos and I can't find mine either!
  • 2 years later...
Well even the guys at my local garage couldn't find the panel without bringing out a big hammer and a magic wand! And after swearing and threatening  - car wouldnt listen - they gave up and refused to do anymore investigating. So I still have a defunct output/cigarette lighter socket! Any ideas folks as I desperately need use of it for camera, satnav, phone etc
Do you think your Toyota dealer could locate it?
It is located drivers side to right of OBD socket under dash, best seen from drivers footwell looking up and has white plastic cover that pops off.
Having trouble posting my pics, but you can just see the white plastic cover in Giggers2010 post above, to left OBD socket in that pic.
If they can't do a bit of basic research find another garage asap (FYI. It's by the drivers right knee, just below the petrol cap release)
https://knigaproavto.ru/shemy/en/toyota/aygo/532-2014-2018-toyota-aygo-ab40-fuse-box-diagram.html
http://www.c1oc.co.uk/forum/viewtopic.php?f=29&t=12250
  • 3 years later...
To be fair, it is very well hidden.  However, at this age, you will probably want to stay away from a garage who doesn't look things up on the internet.
It is cover by a white lid.  The fuses are Mini (Low Profile).
I need to hardwire my Dashcam in the next few days and probably my head-up display as well.
