Avensis t27 tuning
TonySR
Well lads
Have a 2013 avensis t27 2.0 d4d. Just looking into given the car abit more power.
Has anyone use the race chip. 250euro it will give the car 31bhp and 71nm.
Any other ideas will be great :)
Well lads
Get in touch with a know remapper abd get an OBD tune. Much better and safer if it is a quality job done[emoji106]
Sendt fra min SM-G920F med Tapatalk
OBD map be better so 😊
Will look into getting it map
I have an Avensis year 2012, 2.0 diesel, live in denmark.
Mine hold the stock power before OBD 124hp/300nm.
After obd, 152hp/410nm.
Drives like a dream and consumption is better!
That's a nice improvement in power. Was it noticeable.
The power band is must better and it tows the horse trailer like a locomotive, so YES!
I had at power box before that only improve the half of the power and no change in the powerband.
Hartman thank you for the info man. I'm going to look into getting a remap done
Here is the correct numbers and graf for the day they remapped my car.
Before you get a remap take your time and spend som money on a engine decarb clean and injector clean. Then you get the best result in the long run. a931c7cd63ab9883833a3fd428e02029.jpg
  • 3 years later...
Just resurrecting this thread. I got my car, a T27 2011 2.0 4d4 remapped via the ODB port. Definitely drives a lot better, more responsive and better pull. Will report back after a while and report MPG and effect on towing.
No description available.
id love to do mine those lower end torque not good have to rev it above 2000 rpm to make any use its sluggish at low rmps etc .different than my other car a 1.9tdi car i liked it it had more torque at low rpms i wonder would a remap fis this plus will it damage the dpf on my car
Had my car out on a small run today and its a lot better to drive. 50mph in 6th is now a lot easier and the difference in acceleration through the gears 2000-4000rpm is very noticeable.
It now feels like the correct BHP/Torque for the car in my opinion.
