Front Suspension
emobilized
Hi all, new member, decided to join as paid member after reading lots of helpful stuff :) will post an introduction later on
Just a quick question im sure someone here will be able to help me with..
In haste I bought....
03 06 TOYOTA AVENSIS T25 1.8 16V NSF SHOCKER LEG SPRING FRONT
as I have a broken spring on a 07 plate T25 t3x tourer 2.0 d4d
Is the whole unit going to be the same or even just the spring, don't want to take apart without knowing if will fit etc.
Really appreciate your help with this,
Many thanks,
Joe.
Springs and dampers are always sold individually. I suspect that it's the same spring across the t25 range (excluding possibly the rear on an estate version). Give the supplier a ring - they will be able to clarify.
BTW - changing both springs at the same time would be advisable - particularly for the front. The new replacement may not have the same characteristics as the oem spring on the other side leading to possible poor handling.
