T27 headlight replacement
Steve CC
Hi all.
I have a 2009 T27 Petrol Valvematic which has a cracked lens on one of the headlights. It's not an MOT fail but as both lights are a bit foggy I've bought  good second hand replacements.
I can't find any guides on how to replace and it looks like quite an involved job! If anyone can point me in the right direction it would be much appreciated.
Many thanks, Steve
Once you know where the bolts are they aren't too bad to get off and swap. Take all the bolts holding the bumper underneath off, there is 1 half way up each wheel arch behind the liner and small plastic pin you give a half turn and pull out on each wheel arch. under the bonnet remove the from plastic by taking out all the pins, if I remember rightly there's 3 bolts holding the bumper at the top, after the it should come off by tugging at the bumper by starting at the wheel arch. once the bumper is off there is a bolt holding the headlight near the wing and one down by where the top of the bumper just came off, the unit should come out with a good tug. all using a 10mm socket.
