Yaris Breather Filter
breezer
A breather filter normaly goes on the top of your engine block to stop Oily residue escaping and to stop dirt getting in. You won't need one of these unless you have modified your Yaris and have removed some unecessary pipework going into the block as a result of maybe a turbo conversion. You may have seen these on modified cars they are normaly very small miniture versions of a cone filter.
HTH
Kevin
nope, thought it'd give you that ultra cool chavster image though ;)
you could even put a sticker down the side of your door advertising it! :D
get it breezer, it'll make you go faster ;)
Give him a break Sam! He's only asking wot it does or if its any good! :)
Cheers :thumbsup:
well i'm only having a bit of a larf with the young rascal, but if you insnist.
you usually see them on highly modded cars as Kevin from Envy has already explained, most effectively used in conjunction with turbo's (like induction kits)
why not try www.google.com next time you want a question answering breezer? it's quicker, easier and you don't get patronised by nasty guys like myself so much!
