Bumpers
jenncarl
Hi everyone Im new on here Ive got a quick question, does anyone know how the front and back bumpers come off as Ive got a veilside kit to fit if anyony can let me know please :)
alot of bolts to take out , most of which will be rusted in by now , if they snap it needs drilling out tapping a new thread .look under the front valence theres alot there , under the wing liners at both sides , the rears are under the bumper and likely inside the boot at the rear .
Use lots of pentrating fluid on the bolts and leave it to soak in for a day or two and keep re applying in the meantime. When you`ve done that give them a sharp tap with a decent size hammer to break any rust seal. When you replace the bolts use copper grease on the threads. This`ll save problems at a later date. I work on marine engines and this method gets us out of a lot of trouble.
Good Luck. :D
Thanks a lot I will give them a soak today and try to loosen them in a few days cheers for the help on finding the bolts holding them on
