Malfunction light and VSC light on, TPMS light flashing then solid
Just dropped my wife off at her clinic (2 mile run there and back). On way back, malfunction light (engine shaped) came on, vsc light came on and tyre pressure warning light flashing for about a minute, then stays on.
Will be booking it in tomorrow, but in the meantime, any thoughts on the likely issue?
My wifes did something similar once last summer , about 2-3 miles from home. Turned it off and restarted and it was fine and hasn't done it since (touch wood) this bought up some communication fault codes which I cleared.
Tried more than once yesterday evening and again today - same lights stay on when the engine is running.
Booked into dealer.
Faulty # 2 Oxygen sensor is my guess, there was an issue that can affect cars built before June 2016 fixed with a software update and new Sensor
Car at the dealer today, and they've confirmed it is the oxygen sensor. One ordered and will be fitted tomorrow.
Thanks Lee.
Glad you got a resolution, some interesting light combos you had as well, oxygen sensor wasn't my first thought I must admit. We got a Peugeot 108 1.0 2014 in family, so thanks for posting as I now aware of this issue, forums at its best when highlighting 'little features' of cars like this.
  • 2 years later...
I've just had the same problem I'll show this at the dealers.
2015 car.
  • 1 year later...
Just happened on my 2018 Aygo, maybe oxygen sensor too so booked it in for investigation
Oxygen sensor it was done under warranty, would have cost £274
  • 2 months later...
Do you know which oxygen sensor it was? - same issue
Thanks in advance
Connor
read the codes, usually is B1S2, OEM is Denso and around £80-95 range
