1NR-FE clutch
Cyker
Apparently the 1NR-FE uses a concentric slave cylinder rather than a traditional release bearing - Does this still need to be changed when you replace the clutch? Usually when I get a clutch done I make sure they replace the release bearing but don't usually bother with the slave cylinder...
I would change it as a matter of routine. It would be a shame to need taking it all apart again if the slave cylinder fails at a later date.
Same idea with a cambelt change. Renew water pump (if driven by cambelt), idler pulley(s) tensioner while it's all adrift and accessible. Even if they all look to be fine.
Yeah, normally I would but they seem to be really expensive! I was hoping it's like the flywheel, i.e. doesn't need replacing for a much longer time!
The Toyota repair instruction for the clutch list the CSC and the feed pipe as non reusable
Thanks Dev; I was about to ask you and Kingo whether your garages normally replace them when they change clutches!
Oh well, there's a definitive answer rather than an opinion. The price probably reflects that it's made from pure platinum.:laugh:
  • Haha 1
There are two or three versions of CSC, so you need to get the right one.
