03 4.2 Head Unit upgrade issue
Greebs
Hi all,
I'm pulling my hair out on this one!
I bought an Xtrons TD699DAB second hand on eBay and i've installed it into the car. Everything works fine except for the DAB/FM.
Before installing it I went to Halfords and bought a DAB-AA1 aerial and the relevant ISO adapter for the car. I'm not able to get a signal on either DAB or FM/AM on the unit even though everything is plugged in. The only thing that isn't plugged in is the 12v wire from the DAB aerial but I did try having someone place this on the positive terminal of the Battery whilst the unit was on and it made no difference at all.
I'm wondering if anybody else has had a similar issue and hopefully what you did to rectify the problem? I'm beginning to think that the aerial terminal on the head unit is faulty but want to rule out any possible fitting errors that i've made.
TIA
