Carina TA40, rear axel wont budge
Hi!  I own a Carina TA40 and the car today has a welded diff which i'm about to change to a AE86 zenki one. I've reached the point where i should start to pull out the axels from the wheel hub, I use a method i've seen work on youtube where you use the drum brake backside to get more force as you pull it out. My problem is it wont budge more then maybe half a centimeter on both sides,  so it seems its loose, but an other way it seems i've missed something, do anyone have any pro tips for me at this point before I snap?
Have you asked on ToyotaNation forum?
2sav
i managed to fix it, was just the wheel bearing that was stuck, so a few powerful knocks and it came out
