Fuse that’s live all the time
One or more which supply the lights, e.g. side/tail/headlights/ interior light?
Your owner's handbook should list fuses, their ratings and position. There is probably a diagram on the fusebox cover too. Do you own or have access to a multimeter or test lamp? I would assume you do if you're going to mess about with fuses. There are usually small holes in the top of the fuse to test when insitu whether there is power to that fuse. Check them with the ignition off to see which register a voltage or light the test lamp.
