Toyota Celica VVti - High biting point and makes a squeak noise when reversing.
Sporadicus
Hi all
I was wondering if you had any experience regarding a high biting point/clutch where it is pretty much at the top of the pedal. Also when I reverse it begins to squeak.
I believe this cap also feel out of the pedals.
The clutch wasn't this bad until yesterday as I had just picked it up from the garage to get the aerial sealed.
Any advice would be great. I assume it's still safe to drive for a little longer.
Many thanks
Chris
Have you checked your fluids? Gearbox oil? Brake fluid level? (Hydraulic clutch comes form same bottle I believe) may be low
Sent from my iPhone using Tapatalk
I don't have my Celica any more so I can't tell you about the "object" you found...but it does sound as though it's time for a new clutch.!..is it slipping.?..what mileage has it done.?
