Avensis T25 rear wheel bolt replacement
Faz778
Hi folks.
I snapped a rear wheel bolt yesterday on my 04 Avensis (Yes, I know, I'm an idiot).
Does anyone know if the bolts can be replaced without removing the hub assembly, or is there enough room to get the bolt in from the back of the flange and pull it through with a nut?
Cheers.
Yes - new studs can be fitted without any disassembly.
Thanks Gezza. Will the old snapped stud just hammer out?
Yes a hammer and punch will do it.
