1.6 vmatic icon
kingli
hi all does any one know if cruise control could be successfully installed by user on 1.6 vmatic petrol 2015 auris?
many thanks
i have seen a youtube video on this it takes less than 5 mins to install but was curious if it will work on this engine as reports saying that some engines wont work with cruise control..
thanks
There's a pretty big topic about it, main points were that if you have a connector hole already made on your wheel, you can install it (exception is Auris 1.4 d4d, with 1nd-tv engine).
If you have a plugged hole on the side of your steering wheel where CC should be located, then it should also work for you.
@furtula thanks. it has an indentation and looks removable. would it be possible to install without removing airbag connetor? and what is the possible dangers of installing yourself?
i called toyota dealer where i bought the car from they said 'we wont do it'.. thats all. so they were not helpful either.
I only read the topic to kill some time, i had CC as factory.
The instructions are pretty straight forward, and say you should not disconnect the airbag.
If you don't want to risk doing it yourself, i would suggest either asking if someone would be willing to do it for you, or ask for a recommendation for a local place near you.'
42 minutes ago, kingli said:
I called toyota dealer where i bought the car from they said 'we wont do it'.. thats all. so they were not helpful either.
Some dealers may have a policy of not doing work which makes changes to a vehicle's standard spec.
If you buy OE parts to either self install or for a third party install, these would be covered by the parts warranty (usually around 1 year), but the install and the parts won't be covered by the remainder of the new car warranty or the extended warranty provided when the car was purchased.
