Good Morning everyone,
My 2002 Toyota Corolla Verso D4D is not running.  I Started having this issues at the beginning of the year. At first, it took a while for the car to fire up, then it wouldn't start. I suspected a weak Battery and had it replaced as well as all 4 glow plugs.  I checked all fuses and they all checked out good. As of right now, the car only turns but does not fire up. Any thoughts of what I should do?
cheers
Moved to the Corolla club.
  • 4 weeks later...
Check starter
Check your rubber leak off / spill off pipes on the injectors  (not sure if Toyota use them or not) they can go hard and porous and let air into the fuel system causing starting issues.
Having same issue with my Saab - died suddenly, took timing belt out when it died. Repaired damage and will not start....I'm hoping its the crank position sensor, if not that then the camshaft position sensor, and failing that...a faulty injector or 2...
Joys of tempremental diesel cars
I had a diesel once and the reason it wouldn't start was insufficient diesel fuel getting into the engine - the diesel fuel filter was clogged up.
Easy one to overlook
