Jack up the car
Haitham Mohamed
Recently I jacked up the car form front of the car so I see underneath the car to see any solid part to jack up the car  I found a piece of metal as shown in the pic 1 I jacked it up from the place that I marked in the pic 1 after doing my job I return to the home and I see in the user manual and I found that I must to jack up the from another place as I marked in the Pic 2 so my question here is there any wrong happen when I jacked up the car from that place as shown in the Pic 1 or it's normal but I don't repeat it again ??
My car: Toyota Avensis 2008 T25 Saloon
Pic 1 :
Pic 2 :
Don’t worry, the part you jacked up your car from is a solid steel part so no issues with it. Just be carefull when you jack up your car using random areas because jack can slip
