avensis 2009 tr 1.8 saloon clock
alan walthamstow
hi all
got a second hand avensis recently and I have followed the instructions in the manual but find it impossible to be able to adjust the clock. also, there is no multi function display on display and i can't understand why>. it shows mileage and nothing above in the space where the date and temp etc is supposed to be. Any help would be much appreciated. Many thanks.
Alan, can you take some clear photos of the display, changing the display mode each time. Then post them in one of your posts. Make sure the key is in the ON position. Use the DISP button on the steering wheel or DISP button on the instrument cluster to change display to modes.
If you want I could take and post pictures showing the different display modes.
Hopefully you have found out how the car functions work.
Here are some photos of the different modes of the function display:-
Initial turn of the key showing all the warning, status and caution indicators. Current display set to date and time.
Now in current fuel consumption. When driving a bar moves between 0 - 90 mpg. The reading changes instantly depending on how the car is driven.
Average fuel consumption. This is gives an overall reading. Can be reset by press and hold either 'DISP' button over 1 second.
Estimated range based on average fuel consumption and fuel remaining in the tank. Display also set to trip A mode - I reset trip 'A' at last refueling. Use trip button on left of binacle.
Average speed. Reset via DISP buttons.
Seat belt warnings.
Trip B.
Odometer mode. Pressing the ODO/TRIP button on the left to switch between function and resetting TRIP.
There are a couple of other modes not shown, and the important one is the door open warning. The door warning on the display shows which door is open, and warns if a door has not been closed properly when moving off, along with a chime and caution sign.
If your display does not operate and show any of these functions, then something is wrong.
