How to do a diesel purge
Dieselpurge
I have a Toyota Avensis 2005, Does anybody know which pipes are flow and return? I want to run some liquid moly and want to make sure I hook it up correctly.
Pictures of filter: https://m.imgur.com/r/Cartalk/9BPexRk
Can I hook it up like this guide, just remove the two hoses from the filter and put it inside the canister: http://www.liqui-moly.com.au/how-to-clean-your-diesel-fuel-system/
This thread might help...
Trying to do a diesel purge to clean my injectors want to hook it up correctly.
Does anyone know wich is the flow / return pipes om my filter or how i should do this?
Toyota Avensis 2005 D4D 2.0
Topics merged.
There should be two pipes going along the body emerging in the engine compartment.  One should go to the fuel filter - that one is the flow.  The other one should be the return.  I haven't studied your particular engine setup but perhaps the third pipe is an injector weep pipe.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
