Parking brake
nessa
HELP, as I pulled the brake on,it came out way to far and won't go back in far enough. The brake light is on but the brakes aren't  on and i can still drive. Whats happened and can i fix it or will i nedd to take it to a garage.
You might find that the handbrake assembly has broken away from the chassis due to rusted fixing mounts. Yer best taking it to a garage.
Broken cable is more common, and is possible to diy.
